I put a levelling kit on my 97 1500, blocked the rear axle and turned the stock torsion keys up a bit. Now when I back out of my drive way I get a clunk when the wheels are turned all the way to the left. Only in reverse though? Any thoughts
Could use more details like tire size, if your running aftermarket wheels.....
Can't say why your getting a knock... you really shouldn't. Maybe you need to check your CV's. Maybe the extra height is causing an issue with the CV's. If you cranked to far (above 2") the angles on the CV's could be to extreme causing the knock. I'm betting thats what your problem is. Another could be your ball joints.
Good luck
