Maintenance - Capacities, Torque, And Other Misc Info
Thanks to Phillyturbosix for posting this in another topic. I wanted to make it a separate topic for reference. If anyone has something to add PM me and I will put this info in this topic.
CAPACITIES:
Engine, with filter..........6.1 quarts [1]
Cooling System, Initial Fill..........16.4 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 6L90 Initial Fill..........6.1 quarts
Automatic Transmission, 1000 Initial Fill..........7.4 quarts
Automatic Transmission, Total Fill
6 speed 1000..........12.7 quarts
6 speed 6L90..........12.4 quarts
Differential, With 8.25 RingGear Front..........3 pints
Differential, With 9.25 RingGear Front..........3.6 pints
Differential, With 8.60 RingGear Rear..........4.3 pints
Differential, With 9.50, 10.50 Rear..........5.5 pints
Differential, With 11.50 RingGear Rear..........6.4 pints
Transfer Case, BW 4485-NR3..........3.2 pints
Transfer Case, MP 1222, 25,26..........3.2 pints
Transfer Case, MP 1625/1626..........3.2 pints
Transfer Case, MP 3023/3024..........3.2 pints
TORQUES:
Oil Drain Plug.....18 ft/lbs
Transfer Case BW4485
Fill Plug 18 ft/lbs
Drain Plug 18 ft/lbs
Transfer Case MP Series
Fill Plug 13 ft/lbs
Drain Plug 13 ft/lbs
LUBRICANTS & FLUIDS: Lookup Another Vehicle
Engine Oil
Grade 1......API*[1]
Maximum Performance Signature Series 100% Synthetic 0W-30 Motor Oil (AZOQT) Signature Series 100% Synthetic 0W-30 Motor Oil (AZOQT)
Drain Interval Information
Maximum Performance SAE 5W-30 Synthetic Motor Oil (ASLQT) SAE 5W-30 Synthetic Motor Oil (ASLQT)
Performance Plus XL 5W-30 Synthetic Motor Oil (XLFQT) XL 5W-30 Synthetic Motor Oil (XLFQT)
Performance Synthetic 5W30 OE Motor Oil (OEFQT) Synthetic 5W30 OE Motor Oil (OEFQT)
Above -20 F......5W-30
Below -20 F......0W-30, 5W-30 [2]
Automatic Transmission,1000......AF6
Low Viscosity Synthetic ATF (ATLQT)
Automatic Transmission,6L90......AF6
Standard Differential, Front AWD 8.25 AXle......GL-5
All TEMPS......75W-90 [3]
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
Standard Differential, Rear......GL-5
Transfer Case,......AF6
Fluids
Power Steering Fluid......PS
Power Steering Fluid (PSFCN)
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN)
    247.7k
    2.6m
    Lukasz Chmist
    Lukasz Chmist
  • Who's Online   2 Members, 0 Anonymous, 687 Guests (See full list)
