Why No Chips?
Ezrider_92356
i had a chip in my 7.3 power stroke that i had before i bought 8.1L and i found it to be far superior to the hand held programmer, plus liked being able to select different tunes at the turn of a switch, i don't like the idea of sending my pcm to be re flashed because then i am stuck with the tune they install and if i want to detune it for towing real heavy or working the truck real hard for extended periods of time i don't have the option of doing that, programmers typically have very generic tunes and don't offer much benefit. although the main things id like to do on my 8.1L though is remove some of the torque management and maybe advance timing a little bit
You need to look into this:
http://www.gm-trucks.com/forums/index.php?showtopic=117866
You can have several custom tunes and swap between them easily. And a custom tune by BB will blow away any tune you ever had from a chip
I like Pringles.....
but if you are talking about tunes for your truck, if you want to be that picky then do like I did, buy HP Tuners and tune it yourself, then you can also create an unlimited number of tunes to do whatever task you need for the day. Or you can be lazy and let someone else do it for you and you may or may not be satisfied.
