New here, wanna lower my 1500.
I used just coils.  And just leafs on the rear.  A lot of people say to use the DJM 2/4 kit.  It uses control arms up front and shackles and hangers in the rear.  That will keep the ride real close to stock.  I like a stiffer ride and better handleing, so I went with the Hotchkis kit.
From everything I have heard DO NOT use the Belltech spindles.  They hurt you turning radius and make your front tires stick out about .5" further.
well y2k...that is true for the most part, the new belltech spindles aren't the best, they do take away from the turning radius, and with trucks like we have, you need all the turning radius you can get. The hotckis set up is good, but I would recommend djm for the 99+ body style chevy/gmc's The control arms up front are easy to change, and the hanger and shackles are awesome...here are the part numbers and a place that you can order from that comes highly recommended by a lot of sport truck enthusiasts....
www.stylinconcepts.com
Part Number - HS25994 - 4" Hanger and Shackle Kit  •  1999 - 2002  Chevrolet PickUp-C/K or Silverado - Short Bed - 1500 (1/2 Ton)  cost 159.95
Part Number - CA2599L2 2" Lower Control Arms  •  1999 - 2002  Chevrolet PickUp-C/K or Silverado - 1500 (1/2 Ton) Cost 299.95
or go here http://www.djmsuspension.com/Product....rts.htm
The part number for the kit is K2599-L1 It includes everything that i listed above for 491 dollars and some change. Have any other questions....im me on Aol Instant Messenger at Loki da Ravah or email me at [email protected]
almost forgot...you will have to buy new springs too for the drop, but don't get the crappy djm shocks...that is the only thing about djm that sucks...their crappy toxic shocks...i suggest getting doestch tech shock obsorbers...they work very nice. :D and if you have a x-cab, make sure you ask about the carrier bearing assembly when you call djm to order the stuff.
Thanks for your responses, I ordered 3" springs for the front and 4" shackles and hangers for the rear all from stylinconcepts.com.  I'll be getting the control arms in the near future.  I'll post pics when I get it all installed.  Will I have problems on the front end by using springs rather than control arms??
Batch   :D
  • 4 months later...
  • 1 month later...
I need some suggestions...
I have a 2002 ext cab silverado (LS).  I did a 2" shackle in back, noticed that drivers side of the bed saged about a 1/2".  I went to a 2/4 belltech drop (frnt springs/rear shackle & hangers) took out stock bump stop.  Unbelievable how bad it bottomed out!  Still noticed a little sag, moreso w/full tank of gas.  Put 4 toxic shocks on, made a world of difference, but still bottoms out.  Don't want to resort to cutting frame, I see too many people w/trks lowered and I know they all can't be riding like mine.  Any Ideas would be appreciated.  Bty...dealer kinda blew me off, on the lean issue.  I brought in stating bad leafs.  Thanks again
