Hey everyone-
I was curious to find out if I could put on a Z71 suspension system that was removed from a stock Z71 2002 1500.   He had an aftermarket susp lift put on, and I am assuming he has the stock Z71 shocks, lift blocks and spindles.  I have a 99 2wd 1500.  What do y'all think?  Is it possible?  Sorry for the Newbie question
Z71 shocks wont fit a 2wd truck.  I was going to sell mine (took off and replaced with bilsteins) to a guy with a 2wd but it was discovered they wouldnt work
thanks for your replies.
What i am really looking for is a cheap way to get a suspension lift for my 2wd.  I called my local 4wheelparts, and they said it would not work.  Thanks again for your replies.  Anyone here got a cheap susp lift for a 99 2wd silverado?
~$650 bucks will get you a 3" spindle lift from FabTech or ProComp.
See JCWhitney.com or PerformanceAccessories.com
That and a Body Lift would probably be cheapest..  ProComp & Fabtech's 6" Susp Lifts are ~$1400
3" will bring you up to the same hight as the stock z71's and make enough room for those 285's.
