"LINE OF FIRE" LED 'SAFETY' LIGHT BAR
RyanbabZ71
Product Name: "LINE OF FIRE" LED 'SAFETY' LIGHT BAR
Manufacturer: Premier Motoring Accessories
Purchased at: http://www.premiermotoring.net
Cost: $89.00 + shipping
Skill Level: Very Easy
Overall Rating: 10.00
This is a very nice addition for the rear of any full size truck - easy install, plugs into to 4x trailer adapter - or you can scotch it into the trailer harness with a "4 wire truck" adapter.
Works with running, turn and brake lights - very visible - warns the tailgaters.
3M's to the angle piece below tailgate - can be fastend with sheet metal screws if you choose.
gandolphxx,
I had trouble getting your some of your pics to load.  Do you have them installed on the AV?  Are they extremely bright?  Do you have any idea how many LED's make up the strip for the large truck application?
Thanks
Very good! That will sell some! They should give you some royalties. I will add that to my next one. I added some round LED auxillaries with 36/light (I think). They are definitely bright, abrupt and effective.
The other lamps can be replaced with LEDs from LED Tronics
http://www.ledtronics.com and the front page of the GM-TC forum has a good article.
http://www.gm-trucks.com/ART_LED.shtml
"Compared to any other LED bulb we’ve seen on the market, these are king. You get top quality red and yellow LEDs, with clear lenses. Every other manufacture uses colored lenses LED which are less expensive, and do not give out nearly as much light. Brightness is also another quality worth mentioning. Not only do you get more LEDs in the LEDtronics product, but you also get LEDs pointing in multiple directions, giving a more natural and uniform light"
cdnav8r, this may help you find something that will fit the smaller truck, they have double row from 36 to 62 inches and a lot of sizes in between, and also smaller strips you can use for any kind of custom setup you can dream of. This is the stuff they use in rollpans with LED taillights built into them.
http://alter-images.com/cat7.htm
Don't go with alter-images  TRUST ME..
I was one of their distributor's and they are constantly ####ing up orders, and not shipping them correctly or not shipping them at all
if you want great led's that will last forever  go with  precision rod wear   I've used them and they are superb.
thanks for the link,its good to see what else is available out there, as the Line Of Fire light bar is NOT available in a smaller size right now.
