  • 0
Bank 1 Sensor 2
zackafee
Question
0 answers to this question
Not too sure. We replaced ours with an OEM one, and not too long after lost a Cat and had to replace the Y pipe, thankfully the FED emissions warranty covered it.
Hope others will chime in.
Ok. Thanks guys. Do you think i could just take it out and clean it or should i just replace it?
Since your bad sensor is post cat I wouldn't be as worried about the cat being damaged. If it were pre-cat it could effect the fuel mixture which could damage the cat.
I had that same sensor go bad on my Yukon XL Denali. I found an AC Delco replacement online for about $80 and replaced it myself in about 15 minutes.
No...there isnt a y-pipe. Its dual pipes from the manifolds to the muffler. The cats are both on the passenger side...pretty much under the passenger seat.
And i dont think my cats are going bad...my exhaust doesnt stink or anything...but i dunno
