Showing results for tags 'zone 6.5'.
So back when I was in college I put on a 2 inch level and 1.5 BL to clear 33s by 12.5. I still rub but it’s done the job. However I found an insanely good deal on a zone 6.5 suspension kit that I am going to install and remove the two inch level but obviously keep the body lift. might be a dumb question but is the suspension kit a true 6.5 lift? And same for the 1.5 BL? Meaning would I really technically have 8 inches of lift? I plan to upgrade to 35s but just curious
Adding a zone 6.5 inch lift on my 2014 sierra. It has roughly 135k miles on engine. I just replaced front struts and sway bar links (even though kit comes with new links)..realized that after fact. I have steel cast control arms and curious what I should replace? A lot of people on facebook suggest the congnito or zone upper control arms but they are $500 just for the set. I was wondering if I could replace just the ball joints/tie rod ends when I install kit and then down the road replace UCA's with cognito...or is the stock cast steel control arm and ball joint all one piece? Meaning i cant just replace the ball joint? Just looking for some feedback and suggestions. i will have my son in truck a lot so that is why i want to be extra sure I have a solid front end. Any feedback, your pictures of 6.5 inch lifts, and experience with maintenance is appreciated. Been awhile since i posted on here!!
- 2 replies
- 2014 gmc sierra
- zone 6.5
