Showing results for tags 'water buildup'.
My 2015 2500hd diesel has been in Auto nation in Coral Gables dealer for 2 weeks now. It all started with moisture every morning on the interior of my windshield, leading to constant fogging I started emptying out truck and low and behold, I found that the trucks, front Pass rug soaked in water under my waterproof mats, rear rugs were encapsulated in green , white mold and the back seat engulfed in whit mold under the sheepskin covers, which explains the issues I have been having with the radio touchscreen as moisture and mold permeated the whole cab. I took it to the dealer, that until w days ago said the truck did not have any leak, that they used a pressure washer to test and could not find any. So I took to the internet, and found several hundred complaints about water leaks coming from inside of the rear vents behind the back seats that the rubber flaps failed. GM has knowledge of this issue and vent failure but has done nothing about except to replace them with the same defective vent, pursuant to warranty. In my case I will not let that happen as the entire interior has mold that is visible and also spores that cannot be seen. The car is still under factory warranty that has to cover complete replacement to reinstate condition back to condition it was in when I first bought it. I can tell this is going to be an issue, and I have been advised by my counsel to document all interaction in writing, but the only reply from dealer has been an acknowledgement that the leak has been found and that the will contact me regarding repairs. NO OTHER CONTACT HAS BEEN HEARD TO DATE> I cannot fathom the excuse, as there is none. Bad Mojo around this recurring issue GM has not corrected. I am at my wits end my truck only has 9000 miles and sticker was well over &70K. TIME FOR A FORD.
- 11 replies
- water leaks
- flooded interior
