Showing results for tags 'running board lights'.
Since I wanted to keep the factory running boards (I like AMP but the OEM ones look nice to me on the HD and hide the DEF tank) I noticed they would fit a regular DOT 1/2” round side marker perfectly and the ones I used match the OEM smoke lens and amber led. I looked on the net but could not find anyone with out trucks that has done this so I did. Found the wire needed (purple with gray stripe that is connected to the rear 194 tail light bulb) then solder the connections, 2 costs of liquid tape, then 3M electrical tape and all wire ran inside vacuume line and hidden as best as I can inside truck body supports. Cost under $50. Let me know what you think. I will post pics on next post so the replies won’t keep posting the pics. I tied into the wire harness under the driverside cab but you can run wire all the way back to the tail light if you want. Running the wire under the cab to the other side was the hardest part but it is in the support over the trans and had to unbolt (but not remove) the exhaust heat shield. Even though the holes for the led lights are 1/2”, the grommets are 9/16”. And the Diramax running board supports (the 2 next to the DEF tank) are differint and full metal back as the others are plastic areas. Just take off one support/brace at a time, drill the hole and replace. Future replacement should be pretty easy by just pushing the light out the grommet and adding a waterproof quick connect.
Hi guys, hopefully someone out there in GM world can help me. I'm installing an aftermarket running board lights which has courtesy lights and turn signal lights. I looked every where to get some concrete answer where i can tap into the OEM parking lights wire, courtesy light wire, and turn signal wire. Now, I realize i can run them into the hood and into each headlamp but I much rather keep the connections neat inside the cab. I looked at the GMUPFitter manual and quite honestly it might as well be in chinese to me. If any one has any info with pictures broken down Barney style I would appreciate it. Also if you recommend not tapping into any wire coming from the BCM then where would be the best place to tap into? Thanks in advance to everyone who is willing to help! @pgamboa any suggestions?
- 8 replies
- courtesy light
- running board lights
(and 4 more)
