Showing results for tags 'routine maintenance'.
Now that owners are taking delivery of the new 2019 Chevy Silverado and GMC Sierra, I thought a quick reference guide to common routine maintenance items would be beneficial to us all. If you have information that you'd like suggest be added to this topic, just post below and I'll update this first post with any and all new/updated information. 2019 Chevy Silverado & 2019 GMC Sierra Routine Maintenance Quick Reference Guide -------------------------------------------------------------------------------- Digital Owners Manuals 2019 Chevrolet Silverado: 2019_Chevy_Silverado_Owners_Manual.pdf 2019 GMC Sierra: 2019_GMC_Sierra_Owners_Manual.pdf Oil Changes 2.7L(L3B) Capacity: 6.0 Quarts AC Delco Oil Filter: PF66 / 55495105 Drain Plug Size: TBD 5.3L(L84) & 6.2L(L87) Capacity: 8.0 Quarts AC Delco Oil Filter: PF63E / 19330000 Drain Plug Size: 15MM or XX Torx Engine Air Filters With High Capacity Air Cleaner: A3244C / 84121219 Without High Capacity Air Cleaner: A3246C / 84121217 Interior Filters Passenger Compartment Air Filter: CF185 Wiper Blades Drivers & Passenger Sides: 55cm / 21.7 Inches - GM Part Number 23417074 Spark Plugs 2.7L L4: 12688094 / 41-106-IP 4.3L V6: 12622441 / 41-114 5.3L V8 & 6.2L V8: 12622441 / 41-114 Fuel Tank Sizes Standard / Short Box (Gas & 4WD Duramax): 24 Gallons Standard & Short Box (2WD Duramax): 22 Gallons Automatic Transmission Fluid 6-Speed: DEXRON-VI Automatic Transmission Fluid 8-Speed: DEXRON-HP Automatic Transmission Fluid 10-Speed: DEXRON ULV Automatic Transmission Fluid (GM Part Number 19352619/Canada 19352620) Transfer Case Fluid All Models: 1.6 Quarts DEXRON-VI Automatic Transmission Fluid Wheel Lug Nut Torque All Models: 140 lb-ft / 190 N-m
- 21 replies
- 15
