My reverse lights are staying on:
When in park
When in drive
When the ignition is off
I have removed fuse #33 in the engine compartment fuse box which kills power to the revers lights to keep from killing my battery. This also keeps my reverse camera from turning on when in reverse also.
I have unplugged the backup camera thinking this was causing a bad ground with no success.
I don't see where a relay might be that could be bad/stuck.
This is a interment problem which points to ground or relay issue somewhere but I don't know where to look.
