Showing results for tags 'oil dipstick'.
V-6 2019 Silverado calls for 6qts of oil. During an oil change, I drained all the oil out and changed filter. Truck is sitting on level ground, and all oil was drained until the last drop came out. I pre-filled the new filter to the top with oil, which left me with 5 3/4 ish quarts of oil. I put the rest in the truck. I started my truck and let it run for a good five minutes or so. Shut it off, and let it sit for about an hour. I came back out and checked the dipstick my dipstick only shows half way. I even really stuck the dipstick down in the oil and “spun“ it a few times to make sure it picked up all over. Same thing. then I started thinking that Oil was not “sticking“ to parts of this dipstick. As you can see from the picture above; there’s oil on the very top of it, but nothing in the middle section. So I tested my theory and went and stuck the dipstick in an old bottle used oil. It stuck all over it with no problems. i’m guessing it would probably take another half a quart or so to at least to get it up to the full mark. What the hell is the deal ? when Chevrolet specifies 6 quarts of oil for this engine, they clearly state that this is “with filter“.
- 39 replies
- Oil dipstick
- volume
I bought a 2015 Silverado 1500 lt double cab 5.3L V8 4x4 with 12,000 miles on it a couple months ago. It now has just under 20k miles and when I went to check the oil there where metal shavings on the end of the dipstick. Concerningly big metal shavings. I brought it in to my local GM dealer and they told me that it's from the dipstick scraping on the dipstick tube. They didnt run any tests on it they just drained it and looked in the oil itself and didnt find any shavings (so they said). Which sounded a little shady to me so I started looking to see if anyone else had this problem and I found a few cases similar but not enough for me to come to a solid conclusion. The pickup runs great and I dont hear or feel any problems but any insight would be greatly appreciated. I thought about sending a sample to be tested myself but I dont know of any good company's near me that do it. Any recommendations on that would great too. Thanks
- 19 replies
- metal shavings on oil dipstick
- oil dipstick
- (and 4 more)
