Showing results for tags 'oil cooler'.
I have a 1988 GMC k 1500 four-wheel drive 350 tbi Trying to get rid of factory oil cooler lines it's a 3/8 push connect fitting screws into oil filter adapter I need to know the thread type and a half inch fitting screws into radiator oil cooler on side I was told need to find automatic transmission aftermarket braided cooler lines that match the half inch threads on the old cooler and find fittings needed to match the 3/8 thread that screws into the oil filter adapter
Hello Anyone. i have a LBZ Duramax, and i have just put in a new water pump and rebuild the oil cooler and the pipe that connects them i put in after and i pitched a gasket and it eakd then i took it out again and put two non OEM gaskets on there and it seemed to stop leaking when i added coolant but when i fired it all up it pissed out again so my question.. what is the propper way to put the pipe in, i could no imagin putting it in the cooler then putting it back on the truck, do you put it on the water pump first maybe then put it in??? or can you some how use gasket maker instead??? i need help
- duramax
- water pump
