Showing results for tags 'muffler replacement'.
Replaced the stock muffler with the Magnaflow 11229 which has 3” in and out. Initially, the exhaust shop removed both flappers. It sounded very deep and rumbly but a bit louder than I preferred. The drone especially on the highway was unbearable.After emailing Magnaflow support, they recommended I have the shop put the flappers back on so I had both flappers welded back in. The flappers completely eliminated the drone but did quiet down the muffler quite a bit. Now, it’s about 70% as loud as the GM performance exhaust which is the perfect level of loudness I was aiming for. I didn’t want anything obnoxious. Sounds really good when you put your foot in it. Cold start (attached) is equally as lively. If you find the GM performance exhaust a bit too loud for you, then this mod will be the perfect volume level. Just save yourself the headache and money by having the shop install the flappers from the get go. Cost me $220 for muffler and install. $80 to weld the flappers back in. All in all, very pleased with it. AT4 Exhaust.mp4
- 32 replies
- magnaflow
- muffler replacement
