Showing results for tags 'interior mod'.
Hey y'all, I know this has been talked about a bunch but I just for some reason can't find the info I'm after. I have a 2000 Chevy Silverado 1500, with the 5.3 and 4l60e, its a non z71 but with the same gear ratio I believe. Now I have a couple questions. 1. I want to swap to a 6.0 (maybe with some mods like a small cam, headers, maybe an intake), the 5.3 in the truck has been rebuilt but was used as a work truck and is "tired" so to say. I know a lot of people have said that to make the simplest "plug-and-play" setup to grab a 6.0 from 04-06(07 classic?) and it will run on the stock 5.3 tune (but recommend getting it retuned) I know that you can use the stock 4l60e but put some money into it to make it be able to hold the power and torque of a 6.0. I also know that to swap to a 4l80e trans it would require a crossmember and wiring at least, along with a different driveshaft, and since its 4x4, possible a different transfer case? So answering my own question with confirmation from someone, I could use a 04-06(07 classic?) 6.0 and just do a slight build on the stock 4l60e (which is currently slipping hoping just torque converter)? So on to my next question, I want to swap a z71 axle under the truck rather than the stock open diff. Would it be easier to swap out just the diff or to swap the whole axle? Is there any wiring for the limited slip/locking diff in the z71 axle? And is there a difference in the front diff? Also the truck currently is on 33" tires, and I plan to go to 35"s so should I just wait and have the truck regeared with an aftermarket limited slip or locker? And one final question for the interior guys out there. I hate the 99-02 steering wheel. I wanna swap to a 03-06 steering wheel. I know that the airbag itself will fit if I grab it off a 03-04 HD truck because its single stage, but what about the splines on the steering shaft? are those the same as the 99-02 1500 trucks? Or do I still have to swap that out for a newer steering shaft? Also how bad is it to run heated leather seats in these trucks that didn't have them from factory? I'm doing a mini restobuild on the truck but still need it to be a daily driver. Thanks for any input guys!!!
- 2 replies
- engine swap
- z71
I’ve not seen anyone talking about this as a possibility so I’m hoping I can find someone who would know. So I just recently purchased a 2020 Chevy Custom Trail Boss which I think was one of the better packages for the price, minus a few perks. Anyways, I’m curious to know if anyone has attempted to swap the 7” infotainment center out for the 8” infotainment center plus installing the Audio controls on the steer wheel. Can this be done and if so how difficult is this going to be?
- 3 replies
- entertainment system
- interior mod
I recently installed the upgraded digital dash in our LTZ that did not have it thanks to White Automotive and Media Services. The process turned out to be quite a bit more daunting than I had expected. I had found a few posts (here and another better start here) that talked about upgrading the gauge cluster, however I could not find any specific step by step instructions to gain access. Here's the obligatory "After" photo showing our new gauge cluster! With plenty of reasons for everyone to access the radio, center console, and gauge cluster, I thought a step by step tutorial would make the project immensely easier for anyone willing to do it. And trust me, If I can do it, you can do it. This "How To" is a work in progress I just wanted to get it out the before it's fully complete for anyone who wants to do this or has been struggling with how to get the specific trim pieces that are required off. I plan to do this entire process again in the near future so I can create a video showing this process and take additional photographs to fill in what I missed the first time. LAST UPDATE: Feb 21st, 2020 --------------------------------------------------------------------------------------------------- Tools needed 7mm socket with 6 inch extension & ⅜ ratchet , plastic interior trim removal tools, T15 Torx bit Plastic Interior Trim Removal Tools are absolutely necessary. Using metal tools or screw drivers will 100% damage your interior! We used this kit from Amazon that costs around $16. <------ This is not a referral link. Just being helpful and showing as an example. Prepare by cleaning out center console, cup holders, charging area, side console storage areas, and by moving the front driver/passenger seats backwards. Using towels, create a soft area to store interior pieces during work The Steps Pry infotainment decorative chrome/painted trim away, starting at the bottom around the HVAC vents on each side, then the top. Remove square access cover directly next to the accelerator pedal. Remove the 7mm screw under the decorative cover. Place fingers in drivers side footwell console storage area and use moderate force to pull the side of the center console away. You do not have the totally remove the panel. There are approximately 8 clips to pull loose towards the top and front of the panel. Do the same on the passenger side, however there is no screw to remove before the panel will snap out. There are approximately 8 clips to pull loose. You do not have to totally remove the panel. With the center console lid open, use a pry tool to pop the clips holding the top of the center console area to the center console assembly. Pull up and disconnect approximately 10 clips around the cup holders, charging pad and/or storage pad area and up to directly below the radio/climate controls. Do not yank the trim too far away, there are wires connected to the bottom of this trim piece. Gently position the tray as far rearward as possible without removing the wires, or gently remove the wire connectors and place the console on your soft area. Using a pry tool, remove the thin, curved piece of trim directly under the USB/12V/120V Trailer Brake Controls. There are five clips to remove, each releasing directly towards the rear of the vehicle, parallel to the floor of the vehicle. Release two clips on each side then pull gently to remove the center clip. Positi on console tray (if still attached) to remove two T15 screws at bottom of infotainment/climate control unit. Unscrew top four T15 screws holding infotainment/climate control in place at top of unit. Using pry bar, pull infotainment unit away, releasing approximately 8 clips around the unit. Use caution, HVAC ducting will come out with the unit, so only pull directly out. Disconnect Unit or lean out to continue on for access to gauge cluster. Using a plastic pry tool, release the leather infotainment trim, but only along the side of the cluster. Using a plastic pry tool, remove the leather gauge cluster hood. The approximately 6 clips are released pulling straight up. Remove the fuse access panel on the driver’s side door opening. Using a T15 bit, remove the two screws holding the Light Control / 4X4 Switch unit in place. Using a pry tool, pull the Light Control / 4X4 Switch unit directly away from the dash. There are approximately 8 clips holding it in place. Unscrew three 7mm screws holding the front cluster trim piece in place. Using your hands, pry the cluster trim piece away from behind the steering wheel, including the trim piece on the top of the steering wheel column that is attached. Remove four 7mm screws holding gauge cluster in place. For 2019 trucks, slide red locking tab and lift cam lock to remove cluster harness. Reverse steps to reassemble. Please comment with any suggestions, edits, or comments. I'd like this to be as helpful as possible.
