Showing results for tags 'interior lighting'.
I saw a similar post regarding the Opt7 Aura kit, which is what I’m installing, but none of those ports worked for me. I’m in a 2017 Sierra SLT Z71 and have the lights fully working besides the door open wire which needs to be connected to something that turns on when the doors are open or when the interior dome lights are turned on. Any suggestions would be great. I’m not sure if this is true but it looked like some wire ports are in different locations between the 2017 and the 2014-2016 considering the posts I have seen for this install have been from non 2017’s and above.
- 2 replies
- lights
- interior mods
So in the Suburban I was extremely annoyed when I noticed the door handle LEDs, Footwell LEDS, and the overhead DVD consoles all had warm white LED lighting, while the rest of the Suburban had cool white or aqua color accent lighting. I have found a solution for now that will help boost the look a little bit while I get a final solution for beefing up the quality of the accent lighting. Here are some before and afters. The after interior door handle one is actually aqua color like the under seat and dash after photos. For some reason the lighting in my garage messed up that. The color is about as perfect a match to the OEM aqua accent lighting in the truck already. The sad part is my wifes 2016 Equinox comes factory with this color in the handles. I couldn't find an easy way to swap them but I am still working on it. The overhead DVD lighting accent is actually EL it appears so that was harder to show in a picture, but its a lot more mellow at night than the old warm white look. Still some finishing touches to do for the door handles but it is so much better at night now being a muted softer light there than the ugly warm white. I will get some night shots of this as well soon.
- 7 replies
- color change
- led color
