Showing results for tags 'interior light'.
Got oil change yesterday, after that it tells me drivers door open, interior lights work, windows do not let down from drivers control, but will on other doors from their switch, and horn doesn’t blow when locking doors with remote.
- 64 replies
- warning light
- interior light
My issue is a little bit different however none the less an annoying one. So yesterday i bought some led bulbs off amazon to replace the dome lights in my truck, i got them opened them up all looks good and then go to put them in, and as i did they turned on not an issue however they where to small so i have to return them, i put the old one back in and not lights in the dash and dome lights are acting up. So it was the left front one i tried it in and took it back out no others. Now none of the lights turn on by the button inside the truck. (door lights and turning them on by the small switch which turns them all on works just fine. when the door is open i can now turn the light off by pressing the button. now those issues are a little less of a bother to me, however the radio (which still works perfect) now has no lights, same with the driver info center buttons 4wd actuator light and the lights on the steering wheel lights. All the buttons however still work perfect it is just the lights. Any help is much appreciated ! Truck is a 2008 GMC sierra 2500HD SLE Diesel crew cab long box
