Showing results for tags 'indicator failure'.
The first issue is the puddle/domelight's. I first noticed the issue when the puddle lights were flickering when the unlock button was pushed or the door was opened. Also, the interior dome lights would not come on when the door was opened. I've pushed the overhead switch to the on position and sometimes they would flash on quickly and shut off, but most of the time not come on at all. The dome lights come on when the individual buttons are pushed, but not at all with the overhead switch. Anyone know where the fuse is that controls the overhead switch? My second issue is with the left turn signal. On the DIC I got a turn indicator failure for the left rear. The indications are with the blinker activation, the mirror/dash blinker lights will flash normal for about three seconds and then pulse quickly, followed by DIC message. *edit* Brake lights (left) also don't activate. I took the truck in today and got it diagnosed. The diode mod, performed exactly like the steps in this forum, somehow shorted out my BCM. I can't believe that would have done it, considering several other things that BCM controls work without issue. Well, new BCM and programming repair will cost one $675 dollars, all because I forgot to take out the damn diode before going to the dealership. Hard life lessons. sidenote: I also performed the footwell lights modification and I'm certain this somehow factored into the equation. I just removed the bcm and there are no chared areas or visible broken solders. If the bcm shorted out, wouldn't I be able to see something on the circuit board? Can any trained eyes spot any areas of interest where I can snap a closer photo to post. With everyone who has had zero issues with the diode mod, I find it hard to believe this is the case. I think they saw the mod and blamed it all on that right away. Should I even take it as far as to say per the magnuson warranty act, in order for them to decline warranty coverage, they have to prove the diode caused the failures? Financially, what could that lead to in further costs for me, or will they not want to hassle and potentially just fix it? The entire BCM looks unaffected .
- 35 replies
- indicator failure
- dome lights
