Showing results for tags 'high altitude'.
Recently (9 and 10th Oct.) had a drive with my friend (2008 Ford E-350 with 6.0 diesel) in Eastern Sierra area, used route CA-88(Stockton - Alpine Village), 89(Alpine Village - Topaz Lake), 168(Bishop - Sabrina Lake), 120(Mono Lake - Manteca), US-395(Topaz Lake - Bishop), Virginia Lakes Rd. The highest altitude was 9900+ ft at Virginia Lakes, and had a one-night camping at North Lake at 9300+ ft. The performance is expected, it performs like a mid or early 90s Toyota Corolla with 4 adults on board. At the climbing on US-395N, north of Bishop, (37°28'56.9"N 118°34'52.5"W or 37.482478, -118.581256 ), it can barely maintain 70mph, with the stupid and annoying transmission jump between 3rd and 4th gear. I believe it can actually maintain 70mph without problem if the transmission doesn't mess it up. I am planning to convert it into switch-flip manual or use stand-alone controller. And the climbing on CA-168 is really a struggle, barely 40mph, with the stupid and annoying transmission again, jumping between 2nd and 3rd gear, until I have it enough, simply put the shifter at 2, let it revs at 3500 rpm, while 4000 is the red line. So is it performs normal? Any advice on high altitude driving and tuning? Like base ignition timing? The first day, the climbing on CA-88, 89, 168 and Virginia Lakes Rd, my new air filter is higher than original slight a little bit, caused the air cleaner lid can't seal, let hot air in engine bay get sucked in, I guess it's probably make the high altitude air density problem worse. The next day, I made a gasket with shop towels to seal the lid. I feel it performs better, but since I was grouped with my friend, I can't do the test on the same route to see if it really make difference. ========== My vehicle: 1994 Chevy Suburban K2500 Silverado, 454TBI (L19)+4L80E, with towing package, 178k miles. Purchased used at 150k miles. Engine was rebuilted at 75K miles, which is the only known thing, assuming other things are stock, transmission and torque converter are factory original and weresn't rebuilted. New air filter, Engine oil changed at 175k (Mobil full synthetic), transmission oil changed at 150k. Coolant / water is 60%/40%, new radiator cap, no boil happened. (Prestone for GM, orange color) New spark plugs & wire, ignition coil, ignition control module, fuel filter, fuel pump, thermostat at 150k (right after I purchased it). //edit: O2 and MAP sensor are also new, ACDelco. Base ignition timing is 8 BTDC, factory is 4. Load: 1 person (me), camping gears, road emergency kit and 2 boxes of tools for emergency, no trailer. Fuel: Chevron or Shell 91.
