Showing results for tags 'flex fuel'.
Hello all. I have a 2013 silverado w/5.3l flex vin 7. Basically has rough idle in park and drive. Very poor acceleration. Almost seems to bog down when trying to accelerate. It will occasionally surge and for just a split second I can feel a bit of power. Also doesn't want to downshift when I lean on the gas pretty heavy. I've got to do near floor it to get it to down ****** and when it does it will drop down 2 gears a lot of the time. No engine light and it won't set any codes. Showed 0 misfires on all cylinders. Long Fuel trims usually in single digits negs. Fuel pressure 43-46psi at idle and highway. I've replaced throttle position sensor, Accelerator pedal position sensor, manifold pressure sensor, mass air sensor, plugs, coolant temp sensor, oxygen sensors. Fuel pump, intake manifold gaskets twice (now with "updated" steel gaskets), throttle body gasket/seal, injector o-rings (upper and lower). Tested all coils for strong spark. Smoke tested for vac leaks along with propane. It has never failed to start or even had a long start and has never died/stalled. I'm just kinda at a loss at this point. Any help will be appreciated and possibly considered. Thanks
Installing DSX TUNING Flex Fuel Kit
Erny415 posted a topic in 2014-2019 Engine, Driveline, & Exhaust
Hey guys, so I bought the dsx flex fuel kit so I can run E, but I CAN NOT find a single thread or video on how to install it, I usually don't do major work on my vehicles so maybe this will be too much for me and I can take it to a shop. But can someone who has done it try to explain? Pics as well please. I' m sure i'm not the only one who is having a hard time finding instructions on this. TIA!!!! -
Going to be trading my pickup in so I stripped off all the aftermarket stuff. Everything came off a 2014 Chevy Silverado 1500 6.2L High Country crew cab short box Kooks 1 7/8" long tube headers with a Kooks cat-less y-pipe, Cometic header gaskets, Stage 8 locking header bolts, Stage 8 locking y-pipe bolts, and will include 7 new plug wires $1100 + shipping Corsa exhaust with a Flowmaster super series muffler (removed the sport muffler and installed the Flowmaster, did not cut or weld any part of the Corsa system) $900 + shipping Airaid MIT intake tube and K&N filter SOLD Armadillo (gatorback) rear mud flaps and Husky molded front mud flaps $125 shipped Flex fuel sensor and fittings to make it plug and play $50 shipped I am located in Gillette, Wy 82718 for local/close sales.
- 23 replies
