Showing results for tags 'dome light switch'.
The first issue is the puddle/domelight's. I first noticed the issue when the puddle lights were flickering when the unlock button was pushed or the door was opened. Also, the interior dome lights would not come on when the door was opened. I've pushed the overhead switch to the on position and sometimes they would flash on quickly and shut off, but most of the time not come on at all. The dome lights come on when the individual buttons are pushed, but not at all with the overhead switch. Anyone know where the fuse is that controls the overhead switch? My second issue is with the left turn signal. On the DIC I got a turn indicator failure for the left rear. The indications are with the blinker activation, the mirror/dash blinker lights will flash normal for about three seconds and then pulse quickly, followed by DIC message. *edit* Brake lights (left) also done activate. My first action was replacing the bulbs, however that did not fix the problem. When I returned home, I troubleshot the bulbs by placing the lighting switch from auto to running lights and the lights came on, so I know the bulbs harness and wiring are working perfectly fine. I have checked the fuses in the engine compartment, number 14 I believe which is labeled trailer stop/left turn I believe. Any ideas on this issue? I would like to troubleshoot the issues prior to taking it to the dealer under warranty 30 mins away.
- 7 replies
- turn indicator
- blinker
