Hi guys, hopefully someone out there in GM world can help me. I'm installing an aftermarket running board lights which has courtesy lights and turn signal lights. I looked every where to get some concrete answer where i can tap into the OEM parking lights wire, courtesy light wire, and turn signal wire. Now, I realize i can run them into the hood and into each headlamp but I much rather keep the connections neat inside the cab. I looked at the GMUPFitter manual and quite honestly it might as well be in chinese to me. If any one has any info with pictures broken down Barney style I would appreciate it. Also if you recommend not tapping into any wire coming from the BCM then where would be the best place to tap into? Thanks in advance to everyone who is willing to help! @pgamboa any suggestions?
