Showing results for tags 'No fuel'.
I own a 1995 gmc sonoma and it left me sit earlier today. After working on it for awhile I discovered a few problems. The motor had no spark or fuel, I figured out the coil was bad and now it has spark and it starts on starting fluid but the tbi injectors aren't spraying. The fuel pump does prime but we aren't sure of how much pressure it's building. We put in new injectors and cleaned the entire throttle body and fuel is making it to the injectors but the injectors don't fire. Any ideas? Do the injectors require the 12 psi of fuel pressure in order to fire or is there another problem?
- Cranks over
- No start
2011 Chevy 2500 HD duramax. So this is an issue that had only happened a couple of times. And had only happened on the initial start after using autostart on colder days (low 30s). After starting the truck with the auto start, the truck will run for approx 2-4 minutes then stop. The truck will not start again with they key until you you have cycled the ignition a few times. So my guess is I’m losing fuel pressure but this only has happened, so far, when using auto start. If I use the key is used on the cold start there are no issues. And I haven’t experienced these issues at any other time. After the initial start. Anyone else experience the same issue? Cause?
