Showing results for tags 'Hood installation'.
So some of you are probably aware I had a little "incident" requiring me to replace both hood lift spring hinges and the hood hinge supports on both sides. I'm just wondering what order you would assemble it to prevent any further headaches or injury. So far I've marked with a sharpie where the hood hinge supports attach to my hood (three bolts each side) so it'll line up near where it belongs. I was planning on removing the one bolt and nut on each side of the hood near the windshield cowl that holds the hood to the truck. Then having a neighbor help me lift off the hood I will flip it over and install my new hood hinge supports (three bolts each side) I'm wondering should I wait until the hood hinge supports and hood itself are installed before installing the hood hinge that contains the spring (and lifts the hood) on each side? Or when the hood is off should I install the hood spring hinges? My theory would be it might be easier to install the hood without the hood spring assemblies installed yet so it could sit flat instead of in a lifted position. But I very well could be wrong The other option would be to install the hood spring assembly on each side while the hood is off (but would require my helper and I to lift the hood on in a raised position, then attach the hood hinges with the springs to the hood hinge supports in a "hood raised" position. I want to prevent a mistake or any major problem from doing this incorrectly. Also do you know if the hood hinges with the springs attach with the bolt side in or the nut side in? If anyone has access to information that says how this is supposed to be done and would share an image it would be greatly appreciated. If not, what order would you go about doing this? Hood hinge supports first (with the one bolt on each cowl side going in first, then lift hood to install spring assemblies, or install spring assemblies whole the hood is off or do I have this all wrong. Hopefully I made sense out of this because the parts come tomorrow. Thanks very much.
- 3 replies
- Hood hinge
- Hood
(and 5 more)
