Showing results for tags 'Cam sensor'.
Hi all, have 2003 gmc 3500 lb7. It suddenly just would not not start. I pulled a cam sensor code so I changed it, erased code and tried to start it and nothing. I checked codes again and it returned. Does anyone have a wire diagram so I can trace back so I can make sure there is no break . Does it go straight to the ecm?
- 1 reply
- Cam sensor
- Cam code
I’m looking for any information on swapping gen3 5.3 With a gen4 controller (I want to use the 6L80e transmission.) I know the knock sensors are in the valley cover and it has the 24x reluctor and 1x cam sensor. I’ve heard it is possible to relocate the knock sensors to where they are on gen 4 block and swap reluctors and cams to work with the gen 4 controller, does anyone have any experience with actually doing so?
