Showing results for tags '4wd problem'.
Hello, I just signed up to get some help with my work truck. It's a 2005 Silverado 2500HD base model with the 6.0L auto and manual transfer case and has 280,000 kms. The issue I'm having is with the front axle actuator staying locked even with the transfer case in 2wd. I've had this issue for about a month now and previous google searches suggested that the actuator on the front axle might be the culprit so just today I tried replacing the actuator but that did not fix the problem. If I shift the transfer case into 4H and then back to 2H the dash light will go out briefly for a few seconds but then comes on again. Is there a sensor or switch on or inside the transfer case that might have gone bad? Is there a way to test the wiring from the transfer case to the axle actuator? I did notice a wiring plug near the linkage on the transfer case and I pulled it to check for corrosion or water or anything but it was clean and looked fine, I put in some dielectric grease and plugged it back in. The wiring plug into the axle actuator was clean and dry as well. I'm kind of out of ideas now and am hoping someone here may have had the same issue and knows of a fix. TIA
- 2 replies
- 4wd problem
- 4wd issue
Information 4wd off message
Lchitwood posted a topic in 2014-2018 Silverado & Sierra Troubleshooting
Having a 4wd issue not sure whats goin on. Truck seems to not be goin into 4wd can hear the actuator trying. The selector knob shows its in an shifting in an out then get a information message that 4wd is off. An no code are showing. Havent been able to find anyone else with this issue. Tried pulling the 4wd trec fuse an battery. -
Ok I have a 2000 gmc jimmy sle and my 4wd doesn’t work there is no light and also no sound when I click the button but it’s my dads old truck and now mine and he said the old owner melted the wiring harness but I have no idea where it is too fix it could someone help me please (I would only like to fix the 4wd wiring it’s the only thing I care about)
