Showing results for tags '110v power outlet'.
I have a 2014 Sierra Denali and my 110v charging port has stopped working. The little green LED never comes on. I first noticed this with my phone charger, it's for a Nexus 6 with the Qualcomm QuickCharge 2.0 technology. I know this outlet is only rated for 150 watts, but this charger is far less than that. I also tried my Macbook pro charger, rated at 95 watts, and the port still won't work. Anyone else run into this problem? I'm thinking I have a major problem with all my power ports, 12v chargers included. The reason being my KDLinks X1 dashcam keeps going to an all white LCD screen while driving. It just started doing this a couple months ago and never did it before. When I try it on my Dad's 2013 Malibu, it never resets to the white LCD screen. So basic trial and error leads me to believe it's something with my Denali's power ports. Just wanted to check in with everyone here on the forum, as I plan on making a service appointment to get this looked at. But as we all know, they'll probably say NOTHING is wrong with anything, as usual. If I could get some feedback here, at least I can guide the EXPERTS in the right direction on how to fix this problem. Thanks so much!
Hi All, new to the forums, I just bought a 2016 GMC Sierra 2500 HD Denali and I’m having a hard time with the 110v power outlet. Ever since I bought the truck it hasn’t worked. I removed the passenger side panel and checked fuse #35 and noticed it was blown. With the truck off and nothing plugged into the outlet I removed the fuse and the second the new 25amp made contact the fuse blew instantly, I tried it again with another 25 amp fuse and same problem. Took to the dealer and they’re wanting to charge me $600 to diagnose the problem as they have to “rip apart my whole dash” to isolate the issue. I looked inside the outlet and nothing is inside that would short it out. Before buying a plug or an inverter I wanted to ask here if there’s anything else I should try? TIA
