Air Lift is updating its product line to include the new WirelessAir, the premium on-board air
compressor system. This new product will enable wireless control of all brands of air spring load support solutions easier and more convenient than ever.
WirelessAir is a dual-path system that allows you to adjust your air springs independently of each other. This makes it perfect for towing or hauling uneven or top-heavy loads. The updated WirelessAir system improves functionality and ease of accessibility. The new hand-held controller features an LCD display. Air Lift is also introducing a new mobile app, available for free on Apple and Android devices, that allows users to inflate and deflate their air springs from their Bluetooth-enabled phone. Both the app and the controller are programmable with up to three user-defined presets.
Air Lift’s weather-resistant and corrosion-proof manifold has also been completely
reimagined. It now features Bluetooth-connectivity, allowing for two-way communication
between itself and the controller. This improves the integrated diagnostics, including leak
detection and wiring assistance. Upgrades and software updates are now available
using Air Lift’s exclusive firmware-over-the-air technology, through the mobile app.
The Air Lift system is powered by a heavy-duty, 120 PSI, 1.03 CFM, 9% duty cycle, 12V
compressor that seamlessly connects to the pre-assembled wiring harness. WirelessAir
is now also compatible with air tanks, allowing users to store air for use with tires or
other equipment.
Watch for the new products to arrive early this summer. For more information call Air Lift at (517) 999-2121 or check its website for updated info.
air lift
