Lowered 4x4 thread
Hey guys, I know lowering a 4wd isn't for everyone but living in Iowa I need it for winter, yet I want the street truck look. I have a 2016 rcsb Silverado, looking to lower it 3/5 or 4/6. Does anyone know the "safe" range for lowering 4x4's? Please post up pics and what you have lowered yours with.
Thanks!
Edited by wantavant
Thanks!
As low as you want depending on how you want to spend. You will be ssafe with 3 in the front. Anything over 4 may need a little shorter cv shaft. I have known people to drop AWD Denalis ans Silverado SS trucks 5 inch up front.
Lots to learn in the 2014 Lowering thread here: http://www.gm-trucks.com/forums/topic/155864-2014-lowering-drop-kits/
I just lowered my 2015 RCSB Sierra Z71 4x4, after literally months of research. Truck was brand new off the lot, so I would think I am similar to you in your concern of "how low can I go?". My truck will probably never see mud, its a city truck, and the 4x4 feature to me was merely for winter traction.
I originally decided a 3/5........but a few things swayed me away
  • Good chance it would require shortening the drive shaft
  • I didn't want to flip the rear
  • I didn't want top cut anything on a brand new truck, and with a 3/5 you definitely need to cut (or remove) the rear bump stops, and maybe even need to grind off the bump stop brackets.
  • I still wanted to retain ability to tow/haul stuff
So I went mild, with a 2/4
And yes, as everyone will tell you, you will always want to go lower. My logic was, if I am going to go lower, I'll just bag the damn thing
Good points there, I concentrated on the front being that it was 4wd, but yes the rear will need to be notched. more than 5" requires a flip kit. and then driveshaft angles
Thanks for all the insight. Your truck looks awesome but I just know I will end up wanting to do the flip kit. That part doesn't scare me too bad, I just don't want to mess up the 4wd as I need it in the winter. I hope I don't have to shorten the drive shaft, fingers crossed!
If my truck was a couple years old, I would probably be fine (emotionally) with cutting it up. But with a brand new one...........yeesh, I just think "Hi Mr. Car Buyer. Yes, I had the truck lowered, and yes, I had to have the drive shaft shortened, which means if you are buying my truck to use off road, you are kind of screwed"
  • 11 months later...
What wheel/tire size is that?
My old 14 4WD Z71. 5.3, 3.42's. Mcgaughtys 3" drop struts, factory aluminum control arms. 5" rear drop, shackle flip, mcgaughtys rear shocks. Stock driveshafts, stock 275/55R20. Perfect ride, no issues.
Edited by TheMekanik
  • 3 weeks later...
Updated. Moved the rear kit to the 6" setting. We are now 3/6 drop.
Kit is a mix of parts
DJM front lower control arm
Belltech strut front set to 1" drop
Rear Maxtrac flip kit set at 6" setting
Rear Belltech shocks
Edited by JRoyPDX
Best looking lowered truck I have seen!
