6.2 Visual difference from 5.3
GMC-AT
Regarding 2015-2016 6.2 - is there a way to look under the hood and tell if the engine is a 6.2 or 5.3. I know the window sticker, etc will tell you. But I want to know what are some actual visual differences?
Open the gas filler door and look for the premium fuel sticker. Only the 6.2L uses premium.
The only visual difference I know is the PVC hose routing is different between the two engines. I'm not sure if you can see this with the throttle body and factory intake silencer box in place. I don't see the engine listed on the radiator cover stickers.
The PCV vent hose is right by the throttle body on the 6.2. It goes from the crankcase, under the TB, to right on top of the front of the intake manifold.
Whereas the 5.3 runs from under the TB to back on the drivers side of the intake manifold.
6.2L
5.3L
6.2 exhaust comes straight out the back. 5.3 right side exit.
True for GMT900 trucks and SUV.
VORTEC MAX was a badge for the 6.0 Equipped half tons.
I don't know why GM never made a badge for the 6.2.
Motors now are Ecotec3. ECOMAX? No, that doesn't sound right...
