How many miles were on the truck when you bought it and was there some form of oil change history generated through a dealer or an independent shop although not much would show up if the owner had changed their own oil. Just curious if it was a maintenance issue or if there was something off from the start, surely one would think the original owner would have realized it was using a lot of oil, its hard to go back in time and find out the true story of mysteries like this. Well hopefully the warranty company will go for it and just install a new engine, that would be the ideal outcome.
I still have so few miles on my truck as per not quite 9000 and will be changing the oil shortly which has around 2700 miles on it or so and its down so little on the dipstick from where it was at the beginning of this oil change that I could make the "claim" that it uses no oil but in reality would be a very small amount, less than a 1/16 of an inch. Just driving empty/not towing and easy driving so hard to say what it would do if it had a load behind it for oil consumption. So far very impressed with the very minimal oil usage.
I have a 2015 Silverado and sometimes I can not get in to the truck. I use the key to unlock the driver door. Something is locking the truck when I unlock it, last night I left the truck open and this morning it was locked with the mirrors folded in. This happens while driving so it is now a safety issue. I reach down for the folding button and they open, then they close again.
Any advice, thank you,
Ed
Did you ever find a resolution to this?
my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.
would help a ton if anyone has any advice on this or better yet a known solution..
