grimmysnr Posted May 7, 2010 Share Posted May 7, 2010 It seems as my last topic was lost in translation. Anyhow, figured I would repost. I was reading on Hydraulic Body Mounts and was curious if these were an options for a 2010 2500HD? Also what are your opinions on them? Are they needed and do they make a difference in ride quality? Lastly, do they even make them for the 2500? Link to comment Share on other sites More sharing options...
Diesail Posted May 8, 2010 Share Posted May 8, 2010 I believe, but don't hold me to it, that they are standard on the 2010s, and yes they make them for the 2500. Take a look under your cab, if the rear mount is MUCH bigger in diameter than the front mounts then you have them. Everything I have read says they make a big difference. Mine just came yesterday, hope to install them this weekend. Link to comment Share on other sites More sharing options...
grimmysnr Posted May 8, 2010 Author Share Posted May 8, 2010 I believe, but don't hold me to it, that they are standard on the 2010s, and yes they make them for the 2500. Take a look under your cab, if the rear mount is MUCH bigger in diameter than the front mounts then you have them. Everything I have read says they make a big difference. Mine just came yesterday, hope to install them this weekend. What year is your truck and where did you get them from? Link to comment Share on other sites More sharing options...
Diesail Posted May 8, 2010 Share Posted May 8, 2010 I have a 2008 CCSB, I purchased the parts from GMPartsDirect. Thought about trying to convince the dealer to do it but felt it was going to take more energy and time than doing it myself. The TSB says you an upper mount, lower mount and maybe washer depending on the orignal mounts. The washers where only 2.50 each so I went ahead and ordered them just in case. I will try and post some results after the install. Here is the text of the TSB PIT3009L: Suspension Vibration Or Frame Beaming At 40-60 MPH (C/K TRUCKS) #PIT3009L: Suspension Vibration Or Frame Beaming At 40-60 MPH (64-80 KM/H) - keywords front rear shake shock spring tire - (Dec 3, 2009) Subject: Suspension Vibration or Frame Beaming at 40-60 mph (64 - 80 km/h) Models: 1999-2009 Chevrolet Silverado and Silverado Classic 1999-2009 GMC Sierra and Sierra Classic The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI. Condition/Concern: Beam shake vibration is usually felt in the seat and occurring at speeds between 40-50 mph (64 - 80 km/h). Hertz readings using an EVA tool are normally between 8-24 Hz. This condition is most common on extended cab and crew cab models but has also been noted in other models. Recommendation/Instructions: The severity of beam shake may vary from vehicle to vehicle. To determine if the concern is beam shake, please perform the following: •Test drive vehicle to confirm the condition. A beam shake condition will usually respond to concrete type pavements more than asphalt, so the vehicle should be driven over both surfaces if possible. •Place 200-500 pounds in the pickup bed between the closed tailgate and the wheel wells. A beaming condition should dissipate. Note: Tires with excessive Radial Force Variation (RFV) or out-of-roundness can intensify the frame beaming concern. The following radial force variation numbers should be used as a guide: P-Metric tires (2wd 1500) 12 lbs or less P-Metric tires (all others) 24 lbs or less LT-tires 30 lbs or less If the concern is determined to be beam shake, this is a characteristic of the vehicle. GM Engineering has released updated body mounts to reducing this concern for the Crew and Extended Cab Models. There will be no changes made to the Regular Cab Models. FOR CREW AND EXTENDED CAB MODELS, REPLACE THE REAR CAB MOUNTS WITH UPDATED PARTS LISTED BELOW. THESE PARTS SHOULD NOT BE USED ON REGULAR CAB MODELS. Note: 2009 1500 MODELS (WITHOUT RPO Z83) ALREADY HAVE THESE NEW BODY MOUNTS. DO NOT REPLACE THE BODY MOUNTS ON THESE VEHICLES FOR THIS ISSUE. New upper and lower mounts should be installed at the left and right rear cab position. The new LOWER mount is a two piece design, meaning there is a rubber mount with a metal washer. Some models may use a one piece lower mount, meaning the rubber mount has a metal washer molded into it. If the vehicle has the one piece lower mount design, washers (PN 15854745, Qty 2) will be needed to be used with the new lower mount. Note: Some new body mounts may have an oily film covering them. This oily film may be left on the mounts during the assembly process and does not indicate a faulty mount. Do not replace the mount for this issue. Upper Mount 25791031 Qty 2 (DO NOT USE ON 2009 1500 MODELS WITHOUT RPO Z83, see note above) Lower Mount 25791032 Qty 2 (DO NOT USE ON 2009 1500 MODELS WITHOUT RPO Z83, see note above) Washer 15854745 Qty 2 (if needed) Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information. WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION Link to comment Share on other sites More sharing options...
msracing65 Posted November 3, 2010 Share Posted November 3, 2010 I have a 2008 CCSB, I purchased the parts from GMPartsDirect. Thought about trying to convince the dealer to do it but felt it was going to take more energy and time than doing it myself. The TSB says you an upper mount, lower mount and maybe washer depending on the orignal mounts. The washers where only 2.50 each so I went ahead and ordered them just in case. I will try and post some results after the install. Here is the text of the TSB PIT3009L: Suspension Vibration Or Frame Beaming At 40-60 MPH (C/K TRUCKS) #PIT3009L: Suspension Vibration Or Frame Beaming At 40-60 MPH (64-80 KM/H) - keywords front rear shake shock spring tire - (Dec 3, 2009) Subject: Suspension Vibration or Frame Beaming at 40-60 mph (64 - 80 km/h) Models: 1999-2009 Chevrolet Silverado and Silverado Classic 1999-2009 GMC Sierra and Sierra Classic The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI. Condition/Concern: Beam shake vibration is usually felt in the seat and occurring at speeds between 40-50 mph (64 - 80 km/h). Hertz readings using an EVA tool are normally between 8-24 Hz. This condition is most common on extended cab and crew cab models but has also been noted in other models. Recommendation/Instructions: The severity of beam shake may vary from vehicle to vehicle. To determine if the concern is beam shake, please perform the following: •Test drive vehicle to confirm the condition. A beam shake condition will usually respond to concrete type pavements more than asphalt, so the vehicle should be driven over both surfaces if possible. •Place 200-500 pounds in the pickup bed between the closed tailgate and the wheel wells. A beaming condition should dissipate. Note: Tires with excessive Radial Force Variation (RFV) or out-of-roundness can intensify the frame beaming concern. The following radial force variation numbers should be used as a guide: P-Metric tires (2wd 1500) 12 lbs or less P-Metric tires (all others) 24 lbs or less LT-tires 30 lbs or less If the concern is determined to be beam shake, this is a characteristic of the vehicle. GM Engineering has released updated body mounts to reducing this concern for the Crew and Extended Cab Models. There will be no changes made to the Regular Cab Models. FOR CREW AND EXTENDED CAB MODELS, REPLACE THE REAR CAB MOUNTS WITH UPDATED PARTS LISTED BELOW. THESE PARTS SHOULD NOT BE USED ON REGULAR CAB MODELS. Note: 2009 1500 MODELS (WITHOUT RPO Z83) ALREADY HAVE THESE NEW BODY MOUNTS. DO NOT REPLACE THE BODY MOUNTS ON THESE VEHICLES FOR THIS ISSUE. New upper and lower mounts should be installed at the left and right rear cab position. The new LOWER mount is a two piece design, meaning there is a rubber mount with a metal washer. Some models may use a one piece lower mount, meaning the rubber mount has a metal washer molded into it. If the vehicle has the one piece lower mount design, washers (PN 15854745, Qty 2) will be needed to be used with the new lower mount. Note: Some new body mounts may have an oily film covering them. This oily film may be left on the mounts during the assembly process and does not indicate a faulty mount. Do not replace the mount for this issue. Upper Mount 25791031 Qty 2 (DO NOT USE ON 2009 1500 MODELS WITHOUT RPO Z83, see note above) Lower Mount 25791032 Qty 2 (DO NOT USE ON 2009 1500 MODELS WITHOUT RPO Z83, see note above) Washer 15854745 Qty 2 (if needed) Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information. WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION Link to comment Share on other sites More sharing options...
msracing65 Posted November 3, 2010 Share Posted November 3, 2010 Did you ever install the hydraulic body mounts? Did you notice a difference? I have a 2008 CCSB, I purchased the parts from GMPartsDirect. Thought about trying to convince the dealer to do it but felt it was going to take more energy and time than doing it myself. The TSB says you an upper mount, lower mount and maybe washer depending on the orignal mounts. The washers where only 2.50 each so I went ahead and ordered them just in case. I will try and post some results after the install. Here is the text of the TSB PIT3009L: Suspension Vibration Or Frame Beaming At 40-60 MPH (C/K TRUCKS) #PIT3009L: Suspension Vibration Or Frame Beaming At 40-60 MPH (64-80 KM/H) - keywords front rear shake shock spring tire - (Dec 3, 2009) Subject: Suspension Vibration or Frame Beaming at 40-60 mph (64 - 80 km/h) Models: 1999-2009 Chevrolet Silverado and Silverado Classic 1999-2009 GMC Sierra and Sierra Classic The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI. Condition/Concern: Beam shake vibration is usually felt in the seat and occurring at speeds between 40-50 mph (64 - 80 km/h). Hertz readings using an EVA tool are normally between 8-24 Hz. This condition is most common on extended cab and crew cab models but has also been noted in other models. Recommendation/Instructions: The severity of beam shake may vary from vehicle to vehicle. To determine if the concern is beam shake, please perform the following: •Test drive vehicle to confirm the condition. A beam shake condition will usually respond to concrete type pavements more than asphalt, so the vehicle should be driven over both surfaces if possible. •Place 200-500 pounds in the pickup bed between the closed tailgate and the wheel wells. A beaming condition should dissipate. Note: Tires with excessive Radial Force Variation (RFV) or out-of-roundness can intensify the frame beaming concern. The following radial force variation numbers should be used as a guide: P-Metric tires (2wd 1500) 12 lbs or less P-Metric tires (all others) 24 lbs or less LT-tires 30 lbs or less If the concern is determined to be beam shake, this is a characteristic of the vehicle. GM Engineering has released updated body mounts to reducing this concern for the Crew and Extended Cab Models. There will be no changes made to the Regular Cab Models. FOR CREW AND EXTENDED CAB MODELS, REPLACE THE REAR CAB MOUNTS WITH UPDATED PARTS LISTED BELOW. THESE PARTS SHOULD NOT BE USED ON REGULAR CAB MODELS. Note: 2009 1500 MODELS (WITHOUT RPO Z83) ALREADY HAVE THESE NEW BODY MOUNTS. DO NOT REPLACE THE BODY MOUNTS ON THESE VEHICLES FOR THIS ISSUE. New upper and lower mounts should be installed at the left and right rear cab position. The new LOWER mount is a two piece design, meaning there is a rubber mount with a metal washer. Some models may use a one piece lower mount, meaning the rubber mount has a metal washer molded into it. If the vehicle has the one piece lower mount design, washers (PN 15854745, Qty 2) will be needed to be used with the new lower mount. Note: Some new body mounts may have an oily film covering them. This oily film may be left on the mounts during the assembly process and does not indicate a faulty mount. Do not replace the mount for this issue. Upper Mount 25791031 Qty 2 (DO NOT USE ON 2009 1500 MODELS WITHOUT RPO Z83, see note above) Lower Mount 25791032 Qty 2 (DO NOT USE ON 2009 1500 MODELS WITHOUT RPO Z83, see note above) Washer 15854745 Qty 2 (if needed) Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information. WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION Link to comment Share on other sites More sharing options...
eticket Posted December 18, 2010 Share Posted December 18, 2010 I have a pair of thse mounts for sale if anyone is interested. Bought them for my 1999 truck and they don't fit. I believe 2003 is the first official year for the mount switch. [email protected] Link to comment Share on other sites More sharing options...
topdj Posted December 23, 2010 Share Posted December 23, 2010 what would be the cost to get them install on a 2009, or can it be a warranty issue? I drove a 2011 and it does ride nicer for sure Link to comment Share on other sites More sharing options...
aj47 Posted December 24, 2010 Share Posted December 24, 2010 2009 should be covered under warranty. You'll have to convince your dealer that the truck meets the criteria of the tsb. Link to comment Share on other sites More sharing options...
